haris300
- Apr 1, 2014
- 999
I promised Mike@DedicatedPerfection and Caleb@ImpeccableImage that I would share my experience using CarPro Essence with orange Lake Country Hybrids and my Flex 3401. I figured I'd make a new post with some high res results.
I decided to compare the Hybrid's performance to a Meguiar's microfiber cutting pad on my Griot's Garage G21.
Here is the G35 trunk I experimented on.
I ran both machines at speed 4.5 for 3 correcting passes and bumped my speed and pressure down for the final 4th pass.
Microfiber side after correction
Hybrid side after correction
Both combos yielded very impressive correction. It does appear that I had fewer remaining defects on the microfiber pad side, but the Hybrids still performed excellently.
Huge improvement overall.
Here is a video I took that better shows the remaining defects after correcting with both combos. The microfiber side is on the left and the Hybrid side is on the right.
https://youtu.be/QvXRuG1VINQ
A couple of extra passes on the Hybrid side did take care of the remaining defects. I found that it helps to apply a little pressure to get a good amount of correction. Surprisingly, I did not notice any hazing on this paint from the microfiber side. Both combos finished down pretty nicely.
Anyways that's my experience.
Here are some shots of the finished correction job on this G35.
Debadged at customer's request.
Thanks for reading!
Thanks for reading!
