CarPro Rayon Pads
Durallymax
Curious if there are any special cleaning procedures for these and if they need to be cleaned while working.
Tried them out with the Ceriglass last night on one of our heavily scratched windows. After a half hour in the same small section it started to look better with only deeper scratches still there, but man is it a lot of work. I was using a Flex PE14 on setting 3. Rewetting as often as needed.
I would like to know as well. Mine are sitting in the garage dirty. I had an issue with the small 3 inch one coming apart slightly on the edges, probably from my error hitting the trim around the glass.
I would definentley not wet them, here is a good review on how this will become problematic from you wetting a buffing pad on a consistant bases type in youtube (AmmoNYC) an there will be a list of videos that pop up and scroll down till you see how to clean buffing pads, anyhow I would just get a good pad cleaning sulotion like (wolfgang pad werkz) that work with any pad best of luck to you.
