CarPro Reset.. work in Foam Canon?
Badlilstang
About to pickup some CarPro Reset.. I have Cquartz Finest on my car and use Reload to keep it purdy and maintained. I figured I would give Reset a try but was curious if it works ok in an MTM foam canon?
According to carpro it can be used in the foam cannon
In the new products section of the forum there is a thread on carpro reset and a few members there have talked about it foaming very nicely
It will if you will close the foam gun valve completely, to let the minimum water goes in while foaming.
I tested it in my foam lance, and it worked nicely... is it the "best" foam? ... no, but it is still fine.
One thing I noticed is that Reset foam does not seem to cling to the surface nearly as long as other shampoos like CG Honey Dew Snow Foam.
Not sure how Reset compare to Mr. Pink when used on Cquartz Finest coated cars. It may make no difference at all but they advertise it to be used with cquartz finest to keep the finish lasting. Either way I am such a CarPro junkie I will try anything they have.
