Yes , no problem
just clean the leather before you spray... spray on and wipe on with MF.
its good on any surface and will eliminate bad odors ,germs, bacteria etc..
Avi, I was under the impression this product was for fabrics. On surfaces like leather, vinyl, etc, aren't you best served to just completely clean those areas thus removing all the bacteria... And then use this product on fabrics where you can't always get to every bacteria? Educate me please.
Hi CoreyAvi, I was under the impression this product was for fabrics. On surfaces like leather, vinyl, etc, aren't you best served to just completely clean those areas thus removing all the bacteria... And then use this product on fabrics where you can't always get to every bacteria? Educate me please.
it needs reaction with sunlight in order to work right?
between 30 min to 1 hour , no need special light treatment, just apply it and forget.. the car will get light in any case, no need to open the doors too, just small windows open for 30 min is enough.Thank you for your thorough answer Avi. :xyxthumbs: I did understand that it is not a cleaner but did not know it could have benefits on leather, vinyl, etc. I ordered the 120ml a few weeks ago and used it last week. (On clean carpet only) Then I turned the vehicle into the sun from the side and opened all the doors to allow the sunlight to hit it. I lef them open about an hour.
How long would you recommend exposure to sunlight for full reaction?
How long would you recommend exposure to fluorescent for full reaction?
its ok, no need direct sun beam on it.. i would thouroghly clean that carpet with steam wash too , then spray the sopure on.. the light penetrate the car inside...Avi,I have used this product (So2Pure) with great success with spilled rotten milk several month's back in my personal vehicle.
But
I recently had a interior detail that the customer had a spot in the back seat floor board,where his child had puked.This is a vehicle that is a 2 door and it's just NOT possible for sun light to directly hit the carpeted area.How will this affect the performance of the So2Pure to not be activated because of NO light source?
yes, correct. on fabric no need to wipe on.I haven't used my Pure yet. I am assuming you can spray it on fabric? Let it live there and do it's thing?
this is long time coat. will keep the smell and air purified for long time, if not wiped off from the surface.
well, if you use chemical cleaners on surface it will remove the sopure, you will need to spray again.Hi Avi. How do you maintain or clean surfaces treated with So2Pure to maximize its durability?
to maintain it well you can use light wiping with soft MF to remove dust or others.
if surface wasnt touch it will work for 6 months, round about..
if its very wet MF ,yes it will affect the coat. sopure is cost effective compare to its work.so you can coat again if dash is so dirty , on fabric seats it will last longer in not washed.Thanks Avi. It's in my cart so I might as well throw some Q's.
How about an MF damped with just water? Or is has to be just dry MF?
If I use air freshener or some scent, would So2Pure neutralize it also?![]()
