The flat do cover more surface area. The CCS runn a bit cooler and the product migrates to the dimples. The chemical caking up depends on the chemicals.
Without getting to complicated, the CCS pad is a " Closed Cell Structure" pad that STORES product in the little pockets. It's density design stops the product from soaking into the pad. This pad is designed to disburse product longer from the pockets.
Now flat pads generally handles heat well because they are less dense than the closed cell pad. Everything is good until they begin to soak up abit of product and then you deal with heat disbursement and loss of cutting power. What you do get with a flat pad is more surface area on the paint. You may see faster cutting but in my experience you change them with greater frequency.
Now if you like the cutting action of the flat pad, I would tell you to consider the new hybrid LC pads. They are dense like the CCS pad but keep product on the paint longer and cut faster than any pad I'ved used previously. For me, I clean my pad or change my pad after every panel, so I'm unsure of just how far you can take a single pad before cutting is degraded. But I can say that both the LC ccs and Hybird pads are good choices. It's really about how you plan to use them. Cut faster or work product longer.. You choice.
Happy Detailing
Superior Auto Salon
St. Augustine, Florida
Bryan Taylor
I wonder if the larger Hybrid pad is going to be a problem for some DA users.
