I have seen a full thread on a guy wet-sanding and polishing out the back of his iPhone ... I'll try to find it again.
edit- here it is: [DIY] Restoring an Iphone ( Front and Back) - MacRumors Forums
Thanks, I have an android and the back is fine (always been in a case) but I haven't had anything on the front and it isn't cracked, just some mild/small scratches here and there.
I thought maybe they could be polished out?
Most screens for smart phones, laptops, and even TV's, are now using Corning's "Gorilla Glass". Don't know if your particular Android has it or not. (If it was made since 2006, it probably has it.).
If so:
From their web-site:
CHARACTERISTICS
Corning® Gorilla® Glass provides exceptional performance and protection, with distinct advantages over other materials.
Damage resistance: Gorilla Glass is chemically strengthened through an ion-exchange process that creates a deep compression layer on the surface of the glass substrate. This layer acts as “armor” to reduce the introduction of flaws by end users.
Thinner form factor: Depending on application and manufacturer specifications, Gorilla Glass can be produced in thicknesses ranging from 0.5 mm to 2 mm. Even at 0.5 mm, Gorilla Glass retains a performance advantage over other cover materials.
Unparalleled surface quality: Corning’s proprietary fusion process gives Gorilla Glass the same superior surface as all of our high-technology display substrates. This extraordinarily precise, highly automated process produces glass with exceptionally clean, smooth, flat surfaces and outstanding optical clarity.
Compliance with environmental standards: Gorilla Glass is compliant with the Restriction of Hazardous Substances Directive (RoHS).
Compatibility with touch screens: Gorilla Glass is an ideal cover sheet for touch screens. It’s tough enough to handle the surface pressures intrinsic to these devices, and exceptionally thin to enable more sensitive and accurate responses.
Easy-to-clean, wear-resistant coating: Customers can request Gorilla Glass with a special coating, making it easier to clean than other cover glasses – a perfect feature for touch devices.
The unique composition of Gorilla Glass creates a much deeper compression layer than other strengthened glasses.
I suggest contacting Corning for their input on polishing scratches out of their "Gorilla Glass"....It's pretty durable, but also very thin.
If interested...Here's their contact info:
CORNING® GORILLA® GLASS | INNOVATING WITH GORILLA
Corning Incorporated
One Riverfront Plaza
Corning, NY 14831 USA
Email: [email protected]
When I read about Avi's new Ceriglass, this is one of the first applications I thought about.
