Ceramic (type) quick spray?
Whipped500
Member
I asked in a previous thread about something to top meg hybrid ceramic wax after washing or in between washing to give a slick feel a while back. At the time it seemed like there wasn't much on the market that would compliment. Now I looked the other day and there seems to be some choices out there whether it be a sio2 spray sealant or a sio2 detailer spray (if I was reading things correctly).
Anyone care to share what they like, if they have tried a couple?
Has anyone tried a product called "the last coat"? If so, thoughts on it?
I like the meg hybrid ceramic for ease of use when washing but sometimes (winter mostly) I'm forced to use a car wash...I'm looking for something that can be used on a dry vehicle.
Thanks
I know a guy who's used "The Last Coat" and seems pretty happy with it and I believe they have a 2.0 version out now. Myself, I'd go with the new Turtle Wax Ceramic Spray Wax they recently released since it appears to be the same thing, but cheaper.
If you're simply wanting to top HCW with something that would provide a slick finish, I think Beadmaker would be a solid choice since it's fairly cheap and gets rave reviews.
Meguiar’s has their new hybrid ceramic detailer designed for this purpose.
Add CarPro Elixir, which I haven’t used but should meet your needs. I like the PBL SiO2 Detailer.
Elixir is great. That is another good one that I would recommend. Works with any coating. It will leave protection behind.
If you want little to no protection then CarPro Ech20 at 1:20 would be a good option.
Under $30:
I really like Shine Supply Clutch. Great pop and good hydrophobics.
I think Griots 3-1 will be my new fave if it last 3 months. Easiest to apply, Better visuals ( really pops on black) and i think the hydrophobics might be better. Id put it up against any under $30 sio2 product.
Luxury toppers:
Only tried two and no need to move on.
PA Cosmic spritz
Kami Overcoat v1
Only have Overcoat v1 (thanks BP1) to compare to Cosmic. Both almost coating like hydrophobics. Both look great. Cosmic easier to apply than OC v1 so it takes 1st place.
Are you in need of to have a cleaning ability from it like a QD or Waterless Wash!
If not if just on dry paint. I have heard those that dilute Meguiars Hybrid Ceramic Wax to 1:5-1:7. And apply it like you would do with a QD for glossenhancing and that newly waxed feel. Don't use to much of the product and wipe it in and wipe it off with a second mf towel. Some even use HCW on dry paint or when sprayed 1-2 times on the dry paint use a saturated with water mf towel to spread it out and then drying it. Also you can just spraying on some water on the paint with a spray bottle or pump pressure spray bottle and apply HCW and dry it as you do on the first use on bare paint.
Carpro Elixir seems to be a great option to go with for a more QD like product. PA High Gloss as a topper looks awesome on the metallic paints. You use very little of product and is very user friendly but it's a high price on it. I like it a lot on my silver metallic paint. Carpro EcH2O at 1:20 as Guz mentioned is great to get that little extra pop and slick feeling from after a wash.
/ Tony
First initial impressions of Meguiar’s new Hybrid Ceramic Detailer is it’s a gem. Crazy initial hydrophobics, good gloss and slickness, smells different but just as delicious as HCW. Currently trying it out on top of my coatings that I’m working with, should have results to report back on soon for how it’s doing. Few of my local parts stores had it on the shelf already.
Technicians choice ceramic detail spray is the by far the best ceramic spray I've used
Much better than Turtle wax ceramic!
Carpro elixir has the best gloss I've seen.
Sent from my SM-N950U using Autogeekonline mobile app
If looking for detail spray i second Ech20. 3oz to 32oz bottle 1oz of sio2 sealant
If you do want some QD-like cleaning ability, or if you don’t care about cleaning... I’ve been mixing my own Merlin elixir of 1.5oz EcH2O and 2oz PA High Gloss, the rest distilled water in a 32oz bottle. One can replace High Gloss with any SiO2 Spray but using High Gloss is the cat-sass of home made Merlin brews I have found so far). TBH, you could probably use just 1oz of High Gloss because it’s so concentrated, but I’m a waster and stick with 2.
I recommend using mostly on clean surfaces if the SiO2 Spray is pricey (like High Gloss is) and you are trying to remain economical. It can be used very sparingly if just amping shine of a clean surface, including as a drying aid.
I use and like The Last Coat 2.0. I have it on 2 vehicles and have been using Beadmaker on top of it. Crazy depth and gloss. I’ve been using TLC 2.0 on my interiors and I love it! Makes the interior look new not polished. It has the same sheen as it did from the factory. Cleans up effortlessly
Yeah thats alot less then Car pros recommend for a waterless so will be low lubricity. Minimum 10-1.
Thought about using cosmic but cant get myself to do it.
Not really looking for cleaning ability, just want something to add a little slick feel and depth/shine after washing.
I know it won't pair well with the meg hcw wax but I should just use whatever spray wax or detailer I have laying around to get rid of it before buying something else. I think I would like to switch over to having everything be sio2 form.
Try EcH20 at 15:1 or 20:1. IMO it has plenty of lubricity, which isn’t a knock on CarPro’s recommendations, but a compliment to the lubricity of the product. I use 15:1 for WW and I go down to 20:1 for the Merlin Mix because the SiO2 Spray is adding its own additional lubricity.
At 10:1 CarPro streaks my black paint in a way that a spray wax does, basically requiring twice the effort and making the WW not so quick and easy (one of the big draws that a WW should have).
Sent from my iPhone using Tapatalk[/QUOTE]
[/QUOTE]
Will do. 5-1 is way worse. I’ll give 15-1 a shot if that work matbe 20-1
And if you want to try the Merlin but have reservations about squandering liquid gold without knowing the results... try a 16oz bottle (1/2oz Cosmic) or even an 8oz (1/4oz Cosmic) mix.
I should note though, I found High Gloss to specifically be my favorite as it doesn’t last that long to begin with and is extremely shiny, so it’s a natural fit as a Merlin QD, IMO. I’ve never tried Cosmic alone as a Merlin.
