This is the first time I used a ROP. I got a new GG6 and instead of doing paint, I tackled the glass on the wife's DD. I used the CeriGlass with the rayon glass pads on the Griot Garage 6” ROP. Came out great! Highly relieved and impressed with the results. I decided to take some before/after pics….The driversideb4 and after are the most noticeable. I took a pic of the inside of the windshield but it didn’t come out for some reason, it was all black, but looking at the after pics they look crystal clear. Wish the inside before pic came out, oh well I tried. The window edges are still a little crusty because I couldn’t get in there with the machine. Maybe one day I’ll try to hand-polish those areas.
Toyota Corolla. I taped the windshield off and proceeded to get started. I hit it 1/2 and 1/2. I first sprayed once on the 5.5" rayon pad with distilled water. Then I put a bead of CeriGlass around the outside edge of the pad and then spiraled it inward. I didn't bother smearing it with my hand. It is 38 deg out so I had the water handy.
I first set the machine to 2.5 and spread the product lightly across the area (1/2 the windshield). Then I kicked it up to 4.5 and with pressure enough to keep the GG from vibrating proceeded to make a crosshatch pattern stepping the macihine over about 3-4" each time. I stopped the machine, spritzed the windshield with water once or twice lightly, and hit it again. Doing this, the CeriGlass would "cream up" and I polished using a 1" step over on 4.5 with lighter pressure until there were random "clear" spots of glass behind the machine. Once that started happening, I finished that full pass and shut it down. Wiped it and saw I was good. Crystal glass. Repeat for all windows around the car.
Picture 1: looking out driver window before polishing (yes, that is cleaned, clayed and wiped with distilled water prior to doing the polishing)
Picture 2: looking out driver window after polishing - wow
Picture 3: windshield - yes it is perfectly prepped and clean
Pictures 4/5: after polishing from inside looking out - nice
