Radarryan
- Nov 9, 2012
- 778
I just bought some Chemical Guys Diablo Wheel Cleaner Gel to use as my maintenance wheel cleaner. I am using the Chemical Guys "The Duck" foaming spray bottle and will dilute at 1:4 or 1:6 depending on what I read is the ideal ratio for well-maintained, Opti-Coated wheels (I know many say that all you need is a good soap, but for whatever reason I like using a dedicated wheel cleaner).
I was thinking, however, of adding a soap to the water/Diablo mix. I got the idea because Optimum says to add some ONR to the OPC mix if cleaning wheels. I think that this could really help encapsulate the brake dust, dirt, and grime and help make a clean rinsing finish.
What are everyone's thoughts? Should I add a rinseless wash (like ONR), a waterless wash (like UWW+), a low foaming car wash soap, a high foaming car wash soap, or a degreasing soap (like Dawn)? Would it be beneficial to add an ounce or so of a APC?
Is all this overkill? Should I just use the Diablo diluted in a foaming spray bottle? I am all about mixing different things to make the ideal solution. If everyone think's it's worth a try, I'll write up a review (if it hasn't been done yet) but then again, having not used Diablo by itself, I don't know how beneficial my review would be.
Thanks for the feedback and what everyone thinks and happy detailing!
