CG Fabric clean or Lightning Fast
kjn
I had Fabric clean in my cart ready to order until I read about Lightning fast. They both have a ratio of 1:20 which very economical in the long run. From what I gathered FC foams more and has odor eliminators while LF suppose to foam less. So which one to get?
I have both. Personally I like lighting fast better. Fabric clean does foam a lot. Unless you have a hot extractor I would go with LF. Both clean about the same
Sent from my SGH-T999 using Tapatalk 2
I use Fabric clean and i'm very satisfied with it. The remaining foam i usually suck up using a wet vac with no problems.
I am using FC at 20:1, and it seems to be working really good for me.
Not saying other fabric cleaners won't get these types of stains out but Lightning Fast seems to tackle just about anything.
Looks good Scott, what extractor are you using?
Here is an example of CG FC (20:1) that I did recently.
Hmmm decisions decisions, seems like everyone recommend both.
Either one will work just fine. Compare prices and base you decision on that. CG FC is pretty cheap and you will get a lot of use out of a small bottle with mixing it at 20:1.
i have LF and use it 20:1. it has worked great for me.
I use Fabric Clean (20:1) and have had good luck.
General Consensus - You'll be good with either product!
I actually found 20:1 to not be effective so I mix mine at 7:1 with good results every time. Albeit it does foam a lot when I use it at that dilution so I very very lightly spray and it gets stains out no problem.
https://lh4.googleusercontent.com/-oZLu08yEiPk/UltYNANtW1I/AAAAAAAAAIk/OGNfMblghuw/w626-h835-no/P1017099.JPG[IMG][/quote]
Steam, no extractor. Sometimes I bust out the small Bissell.
