theblob640
- Mar 4, 2013
- 550
Is it just me or does the suds for CG Honeydew just don't hold up when cleaning wheels? I don't seem to have a problem on paint, just the wheels. If it matters, my process for cleaning tires/wheels are as follow:
After the first wheel I do not have suds anymore and lubricity doesn't seem to be as slick. I also use 2oz of shampoo in not even 5 gallons of water to make it "stronger". Any of you have this problem or know why this is?
Also, this isn't aimed directly at CG Honeydew, just happens to be what I'm using. Are other car wash soaps the same way and also, would you recommend any other shampoos that works great on wheels and paint?
- Remove loose dirt/dust with a rinse
- Spray WG Tire and Wheel cleaner and let dwell
- Use various brushes to clean wheel
- Give tire a quick brush with tire brush
- Use mothers wheel well brush to give wheel wells a good cleaning
- Rinse
