CG Wet Mirror Finish
i still use CG Wet mirror Finish..
I think it's good Paint cleaner/Glaze product from CG :)
make your clear coat clean and clear before use wax/sealant
Second best glaze they make. IMO.
Behind glossworkz.
I'd go straight to Glossworkz then top with Blacklight and maintain it all after each wash with V7.
Mirror finish is something you'd apply before a car show. Its pure gloss with no fillers. Glossworkz fills like crazy.
I found this stuff to be a bit of a P.I.T.A to remove. I ended up giving it away.
If I remember correctly it can stain plastic moldings but I haven't used it in a long time. I'd pass on it given the better choices out there.
I'm with SilverFox, skip Wet Mirror and do Glossworkz Glaze. I used Wet Mirror once and it's been sitting over a year.
In my experiance Wet Mirror Finish (WMF) is an oily glaze / gloss enhancer. I would only use it if you are going to be putting a true nuba wax over it. I don't think it plays very well with sealants. It is a decent glaze and gloss enhancer but as other shave said there are newer better options. I really like Pima Amigo. I have also heard great things about CG Blacklight and Glossworkz Glaze but have not used them yet.
