Chart The Sequence
Jstar
I am a newbie alright and trying to find some place in these forums if a chart of the various application sequences of sealant/wax combination by make; i.e. PS followed by WG wax.
Wash DG901
Clay Meguiars
Polish Meguiars
Glaze Danase Wet Glaze
Sealant FK1 1000p
Wax Souveran paste
Glaze is optional
Sealants or wax
or
Sealant topped with wax
Thanks sal329. Hope to make the chart bigger in time to see the various combination of products are used in the cleaning and waxing process. I have started with yours in an excel spread sheet and hope to be able to upload this for all to see as it developes.:cheers:
glaze before sealant......thought it was the other way around as the glaze would hinder the sealant to cure on the paint.
Howard
Howard
Danase Wet Galze is a acrylic polymer glaze, unlike most traditional oily glazes. It cures its self to allow a sealant to bond on top of it.
I prefer Danase Wet Glaze over the sealant, but you can put it under it also. I have had good luck with both.
You don't want to use other glazes under sealants, however, as it will reduce their life.
A glaze is used to bring out the paint even more. So why would you use it on top of a sealant? I know DWG can be used either before or after a sealant. RMG, Prima Amigo, PB Black hole, ## Ez Creme are all used before a sealant or wax. A few glazes also have cleaners and fillers in them so they would need to be applied before a sealant.
I'm going to ask a similarly newb question. I use the following products and am not sure if I'm using them correctly.
1) Wash/Dry - pretty easy first step
2) Pinnacle Clay
3) XMT series #4, #3, #1 - based on scratches, swirls, etc.
4) XMT Finishing Glaze
5) Blitz Carnauba wax - got this product as a recommendation
I also have 3M IHG, but have only used it once after washing, then finished with the Blitz. Last item is XMT360 that I used once and followed with Blitz.
Am I doing this right or am I screwing something up? Also, are there other products that I need to or should be using?
***And, sorry Jstar...not trying to hijack your post, but an Excel spreadsheet would work wonders for me. My head spins with all of the recommendations****
