I never complained about this issue, but I've been using All Clean + (the citrus one, right?) on wheels without any harm.
I've used it in 1:10, 1:15, 1:20 and even on these dilutions rate added with some CG Citrus Wash and Gloss on a sprayer with a 'Duck Foamer Sprayer'.
This is my favorite for cleaning wheels and underparts, which I call 'soapy APC'. I also use Soapy APC as clay lube on the wheels to remove stubborn contaminants, cleans easy as gliding the clay back and forth.
In no way this APC+ works like a dedicated wheel cleaner (like that color changing 'stuff'), and it's not the kind of Spray on and Rinse off. You'll have to do some brushing before rinsing clean, but results are always good here.
It's cheap and goes a long way, also it's multi-purpose which a dedicate wheel cleaner isn't.
I also use their (CG) Degreaser Orange and All clean (conventional) on wheels without any problem.
Hope I've helped,
Kind Regards.
