Chemical Guys Citrus Wash and Gloss ratio question in a foam cannon.
Trilitai
Hello. I have the mtm hydro foam lance. I planned to buy the citrus wash & gloss online as I read good reviews about it. I always read online about the ratio for 2 buckets wash but don't see people talk about how much to put for foam cannon.
1. How many oz of cw&g to put in without stripping the lsp?
2. How many oz of cw&g to put in to strip the lsp?
3. For best result, do I put in the citrus wash & gloss first and then fill up the 32oz container with warm water?
Thanks so much!
Fill about 1 inch with cw&g, the rest with water. Set the knob to highest soap dilution. I get 2 cars worth of foam from this method with mtm hydro and a 1700psi electric karcher.
Cw&g or any soap/shampoo likely cant strip lsp in any dilution either. Much talk of that recently on here.
I would say ABOUT 1oz for non-stripping and about 2 for stripping. It foams pretty well IMO.
Thanks so much!
To be honest I just have them pre diluted in a bottle since that stuff is pretty thick in texture wise! I add about 4 ounces to a two liter bottle and spray! When I use to put it direct on a foam cannon I would fill it up with water about 3/4 of the way and add the soap since it tends to foam up! The soap is really good if you just want a simple wash with a glossy finish.
[/URL][/IMG]
when i use the foam cannon i use about 3 ounces of car wash...
