I read that the Chemical Guys Hex Logic pads are made by Buff N Shine and use the same colors as the Buff N Shine flat foam pads. If that's the case, then why does Hex Logic call the green as heavy polishing and the white as regular polishing, but Buff N Shine says that the white is heavy polishing, and the green is regular polishing? For those that have used Hex Logic and/or Buff N Shine pads, which did you find had a more aggressive cut, the white or green pad?
Also, I heard someone say that the orange and yellow pads tend to soften during use, but the green pad stays more consistent and actually provides better cut than the orange and yellow over the long haul. Anyone else find that to be the case, where the orange and yellow start out cutting more and then loose come cut as they soften up during use?
