2011 Kona Blue
- Mar 18, 2015
- 421
My wife and I have a part time detailing business which we started this year. We have been off the hook busy with customers and going through pads like crazy. Currently been using Lake County foam pads, yellow, orange, green, etc and they have been holding up decent.
I recently decided to give Chemical Guys a try on their cutting pads, orange. I have tried several different kinds of foam pads and I have to tell you, THEY $uck! The backing of the velcro pulls apart after a few rounds with it. I can't even make it through half a car without the pads getting jacked up.
It seems to mostly occur when I'm on speed setting 6 with my Porter Cable 7424 using the orange pads. The CG pads heat up and pull apart. I even bought that new quad pad with the hole in it to reduce heat. That didn't do $hit, it still pulled apart. They suck.
I have had Lake County pads sometimes do that but for the most part they hold up. I need something very durable for pads and will last. Any recommendations on pads or should I stick with Lake County foam pads. I need good cutting pads and all in one pads for cleaner waxes.
Any guidance would be great. Stay away from CG pads
