Chemical guys wet mirror finish
watson1000
Has anyone used this product ? If you did were you impressed?
Glenn Feed back please
I've used it several times. It's a combo gloss enhancer/sealant....kind of like Blacklight but w/o abrasives.
I apply it after polishing, give it 30 minutes to cure and then top it with a carnauba....CG says it does not have to be topped as WMF does offer some protection. It can alsoe used to top sealants to add alittle wetness.
So if I use this Cg wmf could I top with Collinite 845 or would that be a waste of product / remove any gloss enhancing the WMF roduced on the paint?
I have not topped WMF with Collinite 845, but I would say that cured WMF should hold up to the solvents in Collinite.
After buffing the WMF off, let it cure for 30-45 minutes, and then top. Perhaps just try WMF/845 on the hood and see what you think.
If you are going for max durability, then I would not use the WMF and just apply the 845 to clean/prepped paint. 845 looks pretty good on its own.
I use WMF and I like the look it gives, its a very sharp and glossy look, not much in the warmth department. I top it with BFWDPS and then BFMS over that and it looks great
Thanks guys for all the replys .
I purchased some and just got around to using it on the weekend . I did my spring cleaning ,little late , on my 2011 Edge and the product worked good and I thought it did brighten the White tricoat paint.
I washed , deironized,washed , clayed and then buffed wet mirror finish on with a red pad on speed 2.5 on my makita rotary. I then let the truck sit overnight and then applied collinite 845 over the top .I think it looks good and the finish is super smooth ,slick and beads like crazy.I was stupid and didn't think of taking pictures ,I will the next wash and post .
Glenn
