Autogeek Swirl Removers & Compounds Comparison Chart
Are the mild swirl removers like PB polish and PB Polish 2 chemical or abrasive and do they cut?
Jenn
PB Pro Polish is a chemical polish with no abrasivesAutogeek Swirl Removers & Compounds Comparison Chart
Jenn
Dodo lime prime lite is super easy to use. The regular lime prime has abrasives, the lite version does not.The Pinnacle product was a little difficult to work with (difficult to remove). Are any of the others easier to use?
Jenn
Jenn
Jenn, your problem may be that you were letting the product dry. Remove as soon as you are done working an area.
Very Easy .... IMO....is WDGPS easy or difficult to work with?
Jenn
hmm, maybe I will go ahead and try it then. I read in two thread, dodo juice guy himself saying it could be a ##### to work with - so that put me off.Dodo lime prime lite is super easy to use. The regular lime prime has abrasives, the lite version does not.
PB Pro Polish 2 is a chemical polish with abrasives in it.
Remember you media is also factored into the cutting ability, so it is possible to get some cut with a non-abrasive polish if you use a pad that is capable of cutting.
