Add 4 oz. of common rubbing alcohol to a clean 1-quart spray bottle.
Add three to five drops of liquid dishwashing detergent. No more.
Rubbing alcohol tends to make a mixture thinner, not more slippery, which is the opposite of what you want.What do you guys think about this recipe?
The clay needs to be floated across the surface of the paint on a thin film of lubricant. You can use Meguires Quick Detailer, Mothers Instant Detailer or any number of other manufacturers' version of detailer spray, but you can easily make your own lube spray for pennies per quart. Here is the recipe the pros use — people who do hundreds of cars per month:
You can get rubbing alcohol at any drug store or super-market and even most convenience stores. It may be labeled as "isopropyl alcohol" or "isopropanol". The cheaper 70% solution is preferred.
Fill up the rest of the way with distilled water.
Sent from my cm_tenderloin using AG Online
I bought a gallon of clay lube at a local detail supply store and it smelled just like the big mint that you find laying in a urinal. Seriously!! I use ONR for clay lube for normal use and for extremely thrashed cars I've used Poorboy's World "Bug Squash", it actually works well for really nasty paint and for light paint overspray too.I've used Meguiars quick detailer, Wolfgangs clay lube ,and ORN. They at all great but I have to admit WGs is the best smell I've smelt, lube is great,same with Meguiars , I have noticed with ONR it tends to catches a little so you tend use a more.
Sent from my iPad using Tapatalk HD
