How to clay your car
For Kyle Tucker's 1970 Chevelle "The Villain" - we used Mothers California Gold Clay Bar Paint Saving System.
Step 1: Kneed the Mothers clay bar into a patty about the size of a pancake.
Step 2: Spray some Mothers Instant Detailer onto a section of paint.
Step 3: Rub the clay patty back and forth using straight line motions over the section of paint.
Step 4: After you feel the clay patty begin to glide effortlessly over the paint stop claying and use a clean microfiber towel to wipe off the residue.
This section is now clayed and you can now move onto a new section of paint. Divide body panels of your car into smaller sections, about 2 feet by 2 feet or smaller and after claying a section and wiping it dry, move onto a new section until you have clayed all the horizontal surfaces. If you feel contaminants on the vertical panels using the baggie test you can clay these surfaces too.
After claying your car you should apply a fresh coat of wax. The Mothers Clay Bar Kit includes a sample of Mothers Synthetic Wax which contains enough wax to cover an average size passenger car.
Here's AJ about to inspect the paint using the Baggie Test
Use a light touch - that's all that's needed to inspect your car's paint for contamination.
You can also inspect glass and other hard surfaces and if you discover little bumps it's okay to clay these surfaces also.
Mike explains where contamination comes from, which are any type of air-borne contaminants like,
- Overspray paint
- Industrial fallout
- Traffic pollution
- Tree Sap Mist
Mother's clay bars come in a protective plastic wrap to keep them clean until ready to use. Before using the clay bar remove it from the plastic wrapper.
Next using your thumbs and fingers, knead the clay bar into a patty about the size of a pancake.
Spray a section of paint using the Mothers Instant Detailer. Use enough product to make the surface wet so the clay patty will glide over the paint.
Then placing your had flat against the patty of clay, rub the clay patty in a back and forth motion over a section of paint.
Normally you'll feel the clay patty drag a little as it is removing contamination. As the contaminants are removed the clay will begin to glide effortlessly. This is a sign the contaminants on this section of paint have been successfully removed.
Next step...
After claying a section, use the Mothers microfiber towel to remove the residues and then move onto a new section. Repeat this till all the contaminated panels are clean and smooth.
