Normally i would use a steamer along with some long bristle brushes and a little apc. The steam gets deep into the vent
IMO using a steamer to clean vents is not a good idea because all you’re really doing is introducing a bunch of moisture inside the dash. There’s no cleaning or disinfecting going on when you steam into the vents.
If you take your steamer and hold it several inches from your hand you’ll just wind up with a wet hand and nothing else, and the same thing happens when you steam into your vents.
The most effective way to easily clean dirty vents is to use foam swabs sprayed with your choice of cleaner.
Over time, dirt and dust can accumulate in car AC vents. If neglected, they would cause polluted air within your car and even mold growth, which emits a musty odor. That is why car vent cleaning must be regularly done once or twice a month or more if necessary.
