Cleaning Aluminum Rims
timsatx
What would you use for cleaning these rims? They are not coated but they are difficult to work on, especially the rear with the little rim and large rotors. I know I have a bunch of grime to clean off of them. Not really sure about polishing them.
Take a look at Meguiar's "Hot Rims Aluminum Wheel Cleaner" (G-143).
It's for uncoated aluminum and alloy wheels, might be your answer.
Bill
You know, I have seen S100 products for years. A long long time ago I used it and didn't think it was all that great. I wonder if anything has changed?
I have used the other Meguiar's rim cleaner in the purple bottle. Maybe I can try the blue bottle. I have also seen the Flitz Preclean that Mike Phillips did on some rims that seemed like it worked fairly well.
It has served me well. I usually have 10-15 motorcycles at any given time and use S100 when any of them need to be washed. My bikes stay really clean so washing is a rarity though.
S100 is safe on all surfaces and water soluble so of course rinses away easily. They also make a wheel cleaner that is specific to the task so you may want to look into that. It is in the link I provided.
Good luck and safe riding!
Charles
Sounds like you already got some good answers, but I'll chime in.
Griot's Garage Heavy Duty Wheel Cleaner, Griots wheel cleaner, hd wheel cleaner
Breaks down road grime and brake dust without acids
Griot's Garage Heavy Duty Wheel Cleaner packs a powerful punch against road grime and brake dust, yet it's safe and gentle on all wheel finishes. The high viscosity formula clings to the wheel face to deliver targeted cleaning muscle.
Use Griot's Garage Heavy Duty Wheel Cleaner on your painted, chrome, powder coated, and uncoated aluminum wheels with confidence.
I love using Marvel Mystery Oil
First I apply a little to a terry cloth rag and start wiping, the gunk just melts off.
I follow with an APC then polish.
Sent from my iPad using Autogeekonline mobile app
You can make a cheap and effective solution to clean your alloy rim.
Use a cup of vinegar to a cup of water. You can also use cream of tartar or lemon juice. Mix them and try using the mixture...
I've heard #0000 steel wool works magic on uncoated aluminum rims. I've always done it by hand with Blue Magic, because I went to The Citadel and assume that everything shiny is derived from pain.
Abandoning that line of thinking, I'm considering taking the #0000 steel wool out for a walk on the old '96 F-150 aluminum this weekend.
