cleaning extractor spray nozzles
wrb_subie
Seems as though over the time I probably have hard water (calcium I would assume) buildup in the spray nozzles of my mytee lite extractor. When I spray it the streams kind of have a mind of their own and go every which direction. If anyone here has had this issue and cleaned the nozzles what did you use? Thanks
Quick google search, I guess white vinegar works.
Sometimes tiny stones get stuck in the tip. Unscrew the tip and use a compressor to blow it out and clean it.
AG sells the Mytee system maintainer, $6.99. I used it in my Mytee 8070
