1EdgeKilla
- May 15, 2015
- 65
Hey guys, just curious how you all are cleaning your foam pads of HD Speed or any AIO with a sealant in it. I've been using CG pad cleaner as it came with some hex logic pads I purchased a while ago and just wanted to use it up before buying something else. It however isn't getting the job done even after soaking. I've tried dawn, microfiber wash, and even Hi-Intensity with no luck. I did some reading and saw some suggest wax and grease remover as well as mineral spirits but wanted to double check what you guys thought...
Thanks!
Thanks!
