Cleaning foam pads
In washer with just detergent, yes. Done it numerous times, however they don't seem to get as clean as by hand.
I now have XMT pad cleaner and it works great. Before that I used APC in the sink and it also worked great. Either way is ok. Once in a while I throw a bunch of them in the washer with an MF cleaner and it works well. Hope this helps. Do not mix pads and towels.
using a pad cleaner is best, I just bought some, but b4 that Ijust used dawn or Ivory and hot water. You could use some GP (aka APC) 409 would work pretty good I think. but I got mine very clean just by Ivory and hot water.work your fingers all over pad pushing from middle to edges. rinse untill all soap is out and place with fluf side for velcro up. I have used my wifes baking cooling rack so air gets uner them also (yea she was ok with it,,, I just had to bleach the rack for her LOLOL)
I just use APC, spray it on them and massage in with my hands, rinse, repeat. Dirty pads take 2 or 3 rinses, but works well for me.
Wolfgang or Detailer's pad rejuvenator work amazingly well. My go to for pad cleaning.
I use dawn dishsoap in my laundry tub, works like a charm
I pre cleaned mine with a sink of dawn yesterday, then machine washed. Look brand new.
Sent from my LG-E970 using Tapatalk 2
I immediately throw them in a bucket with dawn, APC, or pad cleaner and water after use (key is immediately after use). I massage the pad to get the cleaning agents soaked thru and let it sit for a bit 20 min or so. I then hand rinse and throw in the washing machine with a "free" detergent.
I'll soak them in the washer sometimes and even run them through a light cycle, but that is about it. Washers are hard on pads. After they've soaked for a while I'll individual brush them and massage them out by hand and then let it go through a light cycle to rinse. I never put pads in the dryer.
I wash mine in the sink with Dawn, let them soak a little while and then rinse them out...
They look like new after.
Put pads in a bucket of Detailer's pad rejuvenator for like 30 minutes. Clean pads with a a brush to get all of the polish residue out of the pads. Then rinse each pad by hand in clean running water. Then spin in washer to get then near dry. Sit on drying rack until dry.
I use dawn dish soap and a soft bristled toothbrush to clean my pads. I only detail my personal vehicles and the random car for a friend or relative, so I'm able to clean my pads immediately. I find that doing this makes for a quick and painless cleanup.
A great way to dry the pads is to use those stackable cookie cooling racks.
Although I consider the price of a pad washer a rip-off, it is one of the best tools in my arsenal and not could not live without it. It really cleans your pads thoroughly. And because you can have it right by your side while working on your project, you don't need to keep a large inventory of foam pads on hand. If you can afford it, I would recommend one. If not, there are some good alternatives to try on this thread.
