Cleaning foam wax applicator
ricedrifter15
Is there a special way or tool that will help me clean my pads faster. I have the 4 inch foam applicators. I use the snappy clean pad cleaning powder. I soak my pads for like 24 hours and they still dont help clean the pads better. It takes me almost an hour to clean off all the wax that was on the applicator. Is there anyway to make this process faster! Anything will help! Thanks.
meg's body solvent + any 2:1 diluted apc. use them together and it takes 30 seconds tops.
When you place them in the Snappy Clean squeeze and run your fingers over the top to help release some product and make room for cleaner to soak in.
Normally just spraying some APC, work it in with fingers and then rinse will do the trick.
Snappy Clean is useful when you are on a tight schedule and have other pads to use while those are soaking.
Well i dont noe if its me or they way i wax. I get a lot of unused wax on the pad. Getin rid of the wax is the only part that takes forever. I have to squeeze all the wax off. Plus the wax is waterproof and its hard to rinse if off with hot water.
pinnacle XMT pad cleaner, its really one of my favorite productsIm the MAN
I like the XMT pad cleaner too. It really makes quick work of cleaning polish out of pads, but I have to admit that I've never used it to remove wax.
