Why not use a a cleaner made for mirco fiber like Pinnacle Mirco Fiber Rejuvenator.Has anyone tried using the Snappy Clean pad cleaning powder to clean their microfiber towels? It looks very similar to the DP Polishing Pad Rejuvenator which is one of the suggested cleaners for microfiber.
I realize I can use cleaners that are labeled for microfiber, but since I don't have any and need to clean some of my towels, I just thought I would ask if anyone has tried the Snappy powder.
I have washed mine with liquid Tide and never had a problem.
I like cutting APC 10:1 I pre-soak my good mf's and after I'm done, I take all my wheel, engine mf's and soak it in the same solution.When you put your microfibers in to soak in degreaser or APC how much do you use?
Jenn
Brilliant! Gonna try this on my next bunch of dirtys. I have a lot of tire & wheel MF's that could use a little TLC!I like cutting APC 10:1 I pre-soak my good mf's and after I'm done, I take all my wheel, engine mf's and soak it in the same solution.
Thanks for the heads up. I just tried this, I put them in a 5 gallon bucket with some APC and set them in the sun to soak. I just checked them and the water is black and the towels look alot better. I'm gonna wash them here in a little bit.I like cutting APC 10:1 I pre-soak my good mf's and after I'm done, I take all my wheel, engine mf's and soak it in the same solution.
