Cleaning pads on the fly with a Flex?
aim4squirrels
Active member
I would assume the terry cloth towel approach does not work with a flex as you cant stop the rotation (might look funny trying though).
Does a pad brush or spur work, or does the oscillation cause problems with that as well?
I use a pad brush with no issues. I've tried the terry method but it'll just basically pull it out of your hand - pad brush is easier / effective.
Good luck!
I have a spur and I only like it for ME pads and wool pads. A brush is good for the foam pads.
Towel works as well but u have to hold it tight
