There's all kinds of ways to clean buffing pads, my how-to book covers this topic with 8 pages of tips and techniques for washing, drying and storing pads.
Here's a simple way, mix some cleaning solution in a bucket of water and as you finish using a pad dunk it in the wash solution and squish it a few times to saturate the pad and then let it soak while you continue buffing out the car. At the end of the buffing day, squeeze and brush the pads to your level of satisfaction and then rinse and dry.
How to dry a foam pad after hand washing
After washing your foam buffing pads by hand the question often comes up,
How do I dry my foam pads?
Here's one way to dry your foam pads, please feel encouraged to find a way that works best for you.
Using a clean, dry cotton terry cloth towel or clean, dry microfiber waffle weave towel or any clean microfiber towel, roll your washed and rinsed pad up inside the towel.
Press the towel into the foam as you're folding the pad into the towel.
Then squeeze, squish and wring the towel which will force any excess water out of the foam and into the towel.
Afterwards, place your foam buffing pads upside down some place where they will stay clean where air can circulate around them and moisture can evaporate out of them.
:xyxthumbs:
