Cleaning pen off of leather?
Kinalyx
My 2 year old just wrote on our white leather couch witha black pen. Any ideas on how to clean it?
i want to know as well. i tried removing some pen marks off a leather purse (not my purse) and nothing i tried worked.
They sell a "pen" to take it off but also takes color out of the leather. Try some apc on 0000 steel wool
This will sound funny but I have tried a ink eraser and it works. Just have to be very careful. I have done it a lot on cars in the past. Ink always gets in the seats and armrest at work. Negligent porters.
Many various types and concentrations of ink.
Many various solutions and suggestions.
Least aggressive first.
Aqua Net hair spray. I'd also suggest blotting it instead of rubbing so you don't smear the ink. Then Lexol leather cleaner followed by Lexol leather conditioner.
Please be careful what you use for removing ink on leather. Using the wrong product may damage the finish on the leather and may not remove the ink.
It is crucial to know the type of leather you have before you try to remove ink from leather as some cleaners (particularly household cleaners ) etc can damage certain types of finish. Many leathers are not finished with a heavy top coat and can be much easier to damage if the wrong product is used.
Removing ink stains from leather is not a cleaning problem.
Most ink removal products will not work simply because of the length of time the ink has been on the leather.
Ink is a dye and has re-coloured the leather (this is what it is meant to do).
The longer the ink has been on the leather the harder it is to remove because it soaks into the
finish. Once it has soaked into the finish you have to use very strong products to remove it, which will also remove finish and pigment which then need replacing.
Pigment/Protected leather
If the ink stain is on a pigmented leather then the first thing you should try is an Ink Removing Gel specifically formulated for leather. (do not use household cleaners like Goo Gone or Krud Kutter which may damage some leather finishes permanently). The fresher the ink the more chance you have of removing it. It is a good idea to have one in your house if you have pale leather and children!!!!
Old ink stains will be harder to remove than a new ink stain and may mean resorting to solvents which will also remove the finish. This is probably best left to the experts.
If an ink stick doesn't work a solvent based remover will need to be used and it may also remove finish and pigment so is best left to the experts.
You should also be using a very good quality leather protect on your leather. This will act like a 'scotchgard' and will make any more mishaps easier to clean off.
You will see many people recommending household products to remove ink – this is not recommended as most simply will not work, some may appear to work but the damage they cause can make a much bigger problem which is then unrepairable (even by a technician).
Aniline Style Leather
As aniline style leathers are largely absorbent it means that the ink will have soaked straight into the leather itself. This makes it impossible to remove. No product will successfully remove the ink.
DO NOT try ink removing products on aniline style leathers as most will leave a greasy residue which will then cause another problem.
Because aniline style leathers are absorbent the ink will carry on moving through the leather and may become less obvious over time. Cleaning and protecting will also help to dissipate the ink.
DO NOT USE THE FOLLOWING ON INK STAINS:
Household cleaners that have not been professionally tested on leather as these are very likely to damage the finish on the leather and will make it much more costly to fix.
Hairspray - This is very risky as it can make the matter far worse by spreading the ink over a bigger area and can sometimes then be impossible to fix. Usually contains alcohol.
Nail Varnish remover/solvents (acetone) - will remove the finish on the leather even if you cannot tell it is doing so and this will then need replacing, and alcohol may do the same depending on the strength of the finish on the leather.
Baby wipes - just about the worst thing you can use on a leather as they break down the finish and will eventually ruin it.
Milk or Toothpaste - these are just silly ideas that will leave sticky residues on the surface which will help to break down the finish on your leather.
Silicones/furniture polish - should not be used on leather. They will form a coating on the surface of the leather which will not allow any moisture to get to the leather itself and will eventually break all the finish down and cause it to crack.
Hide food - will not remove ink and will leave residues on the leather which will attract dirt and oils.
Magic Erasers - these only remove the ink by removing the finish on the leather which will then be expensive to fix.
Please be wary of DIY products that 'guarantee' to remove the ink as the only way these can work is by damaging the finish on the leather
Most leather cleaners will not remove ink unless a very good leather protector has been used on a regular basis!!.
i know its not the same and probably wont help you at all but one of my 6 year olds wrote on a piece of paper on the dash of our montana and it bled through. i tried and tried to get that mark out but it wouldnt budge. finally one day i looked at it had dis-appeared. i guess the sun bled it out.
good luck to ya.
