Rubber can often take several application to fully clean.
I'd start with an APC, might take a couple applications. If that didn't work, I'd ramp things up with degreaser, body prep solvent/IPA and lastly, trisodium phosphate if all else failed.
None of these suggestions are exceptionally good for rubber when used frequently or left to dwell for long periods. Take care with any option and test in an inconspicuous location.
A final option would be a pre-wax cleaner, which likely uses one of the aforementioned products. This can be much more tedious to apply, but result can be great.
