Cleaning wheel barrels when Rinseless washing
Jomax
How do you guys clean inside the rims? I usually use a rim brush when I use water, but it doesn't seem like it would work using one without quite a bit of water.
Do you guys just spray them down and wipe with a MF? And the barrels just don't get cleaned?
Recently did a Lexus IS350F that has High performance brakes and they were bad.
I sprayed them with ONR and used a MF the best I could. I just couldn't clean them inside very well...
I assume no pressure washer?
I would say if he had a pressure washer available there would be no reason to do a Rinseless Wash or clean the wheels with ONR. You could wash the car with car soap (two bucket method) and just spray the wheels with Sonax Full Effect and then rinse. Does this sound correct?
Yes...
that's basically how I do inner wheel barrels,
inside very well...
Without access to free-flowing water sources
(including pressure washers); and, when not removing
tire/wheel assemblies from the vehicles; I find that
there are, quite often, limitations to the total amount
of inner wheel barrel cleaning that can be accomplished
whenever I'm using RWs/WWs.
If the wheels have enough room, I just get in there with a cotton terry towel and wipe it down then toss the towels after.
In my opinion the whole point of a Rinseless Was is to be able to detail a car anywhere without a water source. The Rinseless Wash also saves water and does not produce runoff with chemicals that will flow down the storm drain and contaminate the water supply. It's much more Eco Friendly and meets EPA regulations in drought stricken areas. Plus you can wash your car in the garage in the winter
I use microfiber towels, a demoted wash mitt, or wheel woolies.
In my opinion, wheel woolies are one of the best ways because they carry so much solution.
Another good/cheap option is just getting a grout sponge and cutting it in half.
I have a 2 gallon hand pump that I use to clean the wheels and barrels. I always have wheel cleaner so I have never used RW solution to clean my wheels. I have wheel woolies and I guess I could use the old solution but what I do there is this:
I take a cleaned out empty cat litter jug and place one of my mf gloves over the opening and pour in the old solution. The mf glove acts as a filter and you can actually see particles going into the glove. When done and when I'm done wiping out and rinsing the buckets I just pour the filtered solution back into the jug, add 2 ounces of fresh RW mix and fill the bucket to 3 gallons, done.
Sorry, I know this goes off the tracks a bit but it will surely help someone out.
If no pressure washer,or hose I don't know how you can clean a car using that method.what happens when pull up to a job and the car is filthy I guess you have to make it work.For me I couldn't do it ,will take up so much time only if it was very very lightly dirty.
OP, your not a business, are you? Kinda confused with the previous post a couple back. Buy that 2 gallon hand pump and get some DUB wheel cleaner and some good brushes and you'll be good to go. I've lived in an apartment for a couple years now and it's how I keep my car clean all the time👈
That maybe suggested,but you're not gonna be able to do that with let's say a dirty wheels black f350 pickup for a detail.It would take you 2 hrs just to do all the jams bug wheels etc,maybe good for your car cause you're on top of it ,business wise no.
I'm not a business. But do it for friends/family. This particular car is in a Parking garage at his office. I'm going there once a week. (Just started last week)
Figured someone has to have a good way without water.
I'll be buying what you recommended! Thanks!!
I just use the remaining rinseless product.
It's been proven RW can be effective with minimal marring(no more then a two bucket method). Muddy trucks are a different thing.
But let's me honest, how many cars are too dirty for a RW? Not too man cars going mudding or off-road.
You can do it with a rim brush and some water. After you get done brushing the inside of the barrel, take a spray bottle full of water and spray out the dirty water on the inside.
On my SRT with 20inch wheel's, I'm able to easily clean the barrels using the largest Wheel Woolie or my EZ detail brush.
I typically do a "wheels off detail" bi-annually. Why? Well, I take the wheels off my SRT twice a year to put on and take off my winter wheels, It ends up being a convenient time to do a "wheels off detail".
For a "wheels off detail" I:
  1. Wash and the entire wheel and tire, degrease, and APC (as needed)
  2. Clay the wheel face and barrel
  3. Touch up paint the SRT logo as needed and reclear coat
  4. Protect the wheel with 2x layers of 845
  5. Dress the tire with an oil based dressing (last the entire time the tires are stored)
For a "wheels on detail" I:
  1. Pressure rinse
  2. Foam lance presoak
  3. Two bucket wash with wheel woolies for the barrel (first), lug nut brush for all twenty lug nuts (second), and a chinchilla MF wash mitt for the wheel faces.
  4. then I hand dry with WW towels (wheel only duty)
  5. Occasionally I'll use a rim protector spray coating to assist with repelling brake dust if it's not going to rain or if I'm going drag racing (it only lasts until it rains and it's costly)
Before:
After:
