Clear bra install
Jeff120
Once this pollen settles down Im going to install a clear bra on my car. Ive seen mixed reports about this, should I seal the paint before applying the bra, or have it completely free of polish and sealants?
I have always heard you want the surface free of any wax or sealant.
You want everything stripped. Spray it down with 50/50 Alcohol/Water Mix
If you have a garage and shade...use it.
I always wax the hood after prep before putting down a clear bra. My first job was about 1.5 years ago and there have not been any issues with the edges lifting. Obviously make sure all the solvent has left the wax/sealant before bra application. I started doing this because I read that it's a worthwhile preventative measure to protect the paint. I don't know how necessary it is, or how often damage actually occurs under a clear bra. It may help a little with the install by aiding lubrication, not sure because I always do it. And yes, a VERY clean environment is needed on light paint and absolutely do not try it in the sun!
:iagree: Definitely. But after, if I may...(Just to add an item of interest)---the area/surface that the clear bra will be covering should be as defect free (swirls, scratches, holograms, etc,) as possible, or to your satisfication.
What is the brand name of your clear bra? Usually, during the install you'll be utilizing that bra vendor's supplied (or their preferred/recommended) liquid media that will be applied to the area to assist in the layout. Stripping the area will allow the above mentioned media to do its job more efficiently.
Good luck with your install--you'll be glad you did!
See mixed ideas again! LOL.
Its a 3m bra.
I will do any needed correction, which isnt much, need to touch up some rock chips.
My plan is to polish~probably just need some finish polishing
Repair rock chips
Give it a week or 2 to make sure the repaired chips are dry.
Sealant?~still undecided there
Apply bra
Unfortunately I dont have access to a garage. Once the pollen stops flying I will tackle this project.
Does this process make since? Any tweaks?
Hi!
Glad to hear you are installing clear bra. I have been an installer for over 5 years and would love to offer any help!
unfortunately, i think writing it out on the thread would take me too long, but if you PM me I can give you my number and I can let you know how I would go about installing it.
You can also check out my website to make sure I am a good installer! and that I know what I am talking about.
Clear Bra
I'm in the Los Angeles area.
- Peter
Jeff, while repairing rock chips is ok...be careful.
You want to be level with the paint, if there is any bubbles or defect (from when you do repair the chips) the clearbra will magnify it 10000%
