I appreciated all the input you guys had last time on my last post. We are currently on a job doing a Highway Tractor and was asked to look at another truck while we were there. The hood has extensive damage to the clear coat and so I did a small patch. I hit it 2x with a foam pad with cutting compound. And followed it up with a finishing compound on a foam pad as well. The picture below is a result to that. I was wondering if we need more coats of cutting compound or if this should be wet sanded down.
Any thoughts would be much appreciated.
