Not sure of the cost, but more than I want to pay at the moment. I bought some 1500 and 2000 grit today, I'll sand it smooth and spray some clear coat over it. Won't make too much difference if I'm eventually going to respray the whole thing. If it comes out smooth enough, I may just Plastidip in the pattern of the vinyl wrap I had previously.
Before I sanded and sprayed the clear, I'd try a brush touch-up first.
If you sand and spray the clear coat you are going to end up with a repair and blend area that is at least six-inches in diameter and probably closer to a foot or more. That will look horrible.
If you try the brush touch-up (clear only) you can keep the repair area very small, no larger than the peeled area you are dealing with. In the end, the smaller repair will most likely be less noticeable than the larger "spray" repair.
If it were me, I'd take a single-edge razor blade and probe the edges of the offending clear coat, chipping away any clear that has lost, or has marginal, adhesion. Then lightly scour the exposed based coat with a scotchbrite pad. Do not sand and featheredge the clear coat, rather, use that edge to help contain the clear that you are going to apply. Then apply the clear with a brush staying within the confines of the chipped away clear coat.
At this point you can decide how much more work you want to do... You can stop right here as you have now protected the area from continuing to grow, or you can continue to apply additional clear, as required, sanding and polishing until you are satisfied with the appearance.
Whichever route you choose, be realistic with your expectations... It's never going to be perfect.
