Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
First since this is your first post to our forum...
Welcome to AutogeekOnline! :welcome:
A 16 year old 2000 Subaru Impreza huh? With the original paint? That's 16 years old... hard to wrap my mind around a 2000 Subaru Impreza half way to being considered an antique.
As for removing the overspray, here's the deal... with overspray paint ALL OVER the car the most efficient way to remove ALL of the overspray would be to use a Nanoskin Autoscrub Towel and a foam gun.
That said - If you're going to do this you had already be planning on doing at least ONE machine polishing step to remove any marring from the exhaustive rubbing of a polymerized rubber towel all over the paint.
So before typing any more...
Do you own any type of polisher and do you know how to machine polish paint?
AncientRS said:Hi Mike,
Saw your videos on clay bar & Speedy Prep Towel. I have some automotive 2k urethane clear coat overspray allover my 2000 Subaru Impreza original paint & clear coat. Could you recommend a grade of clay or the towel for the overspray removal? Thank you so much!
Eric
