Clear coated wheels
raswank
What is the best product? Or way to clean them? I use soap and water, but sometimes there are stubborn marks, brake dust flakes and such that won't come off. I am also putting on a new set of wheels on my new accord that are a chrome look wheel that is clear coated. Thanks for any help.
Clear coat treat just like paint. Get all of the tar and brake dust off with a good wheel cleaner or P21S TAW then protect with a wheel wax.
P21s I hear a lot about that. Reg or gel
P21s gel isnt much different from using a strong dilution of car soap and water...
i used some nano and a white ccs pad on my clear coated wheels and finished them off with a coat of pw exp sealant
Hi,
Just a quick question about wheel wax, currently I just just Turtle Wax Platinum wax on my clear coated wheels (I'm sure not using my P21S 100% Carnauba on my wheels :D).
Is there any real difference between using a dedicated "wheel wax" and just using a cheap paint wax? (apart maybe from durability)
Thanks, Matt.
Hi,
Thanks, Matt.
Matt, I can't speak for others, but I perfer a sealant opposed to a wax. Wheels can get very hot and I believe a sealant is more durable than a wax. I have DG501 as a base and use AW weekly after a wash. Brake dust and dirt just washes away with plain soap and water.:cheers:
I had been told that clear coat on wheels is softer than the paint on sheet metal and had seen recommendations for a polish intended for plastics would be a less aggressive way to to clean them up prior to applying the wax or sealant.
I have found a great like of attack for painted wheels, and it works well.
Washing -- P21S Wheel Gel
Drying --- Thick MF Towel
Polishing --- Finishing Polish
Sealant --- DP or Poorboys Wheel Glaze
