Desertnate said:The fact it is already tacky and hard to buff means the solids are already bonding to the surface and you're not going to buff them off
Also, if you are removing the product right away and it's tacky, try reducing the size of the application area.
Excellent - thanks Desertnate. (Mike - do you agree?)
Maybe "tacky" is an exaggeration - not sure. If it's supposed to feel really thin and slick, like, for example, Reload, then no - it doesn't feel like that - there is some resistance against the cloth.
Temperature in mid 20s deg C, unsure of humidity at the time, and no wind.
Just as an aside, it's a shame it only has a 6 month shelf life after opening. Way too much product for me to use in that time. I'd like the option of purchasing a smaller bottle, and also the option of purchasing in a syringe, if that would extend shelf life. (I love how Optimum do it that way - why isn't that idea used by others?)
Hold the phone - date stamp on the bottom of the bottle says ”25 05 20”, which I assume is 25-May-2020. Is that a use by date?
Has a "2020” date stamp - no explicit expiry date - used shortly after purchasing.
