Coating questions? Do they degrade? Are you married to them? Can you go back to a wax or sealant?
Anytime I get questions via e-mail, a PM or a FB message I prefer to invest my typing time where
A: It's easier for me to share links, pictures and videos.
B: More people can read and thus benefit from the information. (no just one set of eyeballs
So I get an e-mail asking,
Hey Mike,
I think you should do a piece on re-applying ceramic coatings when they degrade.
Seems to be a TON of confusion there. I've read they have to be completely buffed off after they degrade in 2-3 years to be reapplied.
Is this true? I
have also read that once you apply ceramic you are married to it from then on, you can't go back to wax and sealants
Thanks
David
Great questions David and "yes" I know first hand there's a LOT of confusing surrounding the topics you bring up.
I think a person could write a book on this topic and unfortunately I don't have time for "this" book so below is my short answer...
First - nothing lasts for ever, not even you or I. I guess if you apply a ceramic coating to your car's paint and then park your car in your garage and never take the car outside again then I guess a ceramic coating could last forever but you wouldn't get to enjoy the car very much, at least not from a driving point of view.
In my opinion, there's no way to REALLY know what's on the surface of your car's paint at the molecular level. Someday when science can shrink us down to the size of an Atom I guess we could shrink ourselves down and walk around on the surface of our car's paint and take a real-time inventory. Until that day then the next best thing you can do where you can REALLY take comfort in knowing you've removed anything that was previously applied and got back down to a clean base of paint - is to go ahead and re-polish or if you think it's needed then re-compound the car and put the car though the coating process all over again.
As far as being married to a coating after using it I call BS on that one. I won't even take the time to type out why I say this.
If you're done with using a coating, wash your car, clay if needed, machine polish the paint and put whatever you want on it and my guess is it's going to LOOK GREAT! :laughing:
My own personal take is this (I've shared this for the last couple of years on this forum)
If the car in question is a daily driver and especially if you live in an area where you drive the car in the rain, then the COATING is going to get a dirt stain from road grime just like the paint on a car gets if you use a car wax or a synthetic paint sealant on it to protect it.
To me this means that coatings or ANYTIHNG that claims to last more than a year is a great idea but if you want your car to look it's BEST then at least once a year you need to do some form of mechanical cleaning to the paint to remove the dirt stain that build-up as normal wear-n-tear for daily drivers.
So in my opinion, if you want to apply a coating to your car, you only need a coating that boasts it lasts for a year.
I think that most of the people that would be a member of this forum or lurk on it or any Facebook group, are also the type of people that CANNTO go an entire year without doing something to their car's paint thus a 2, 3, 4, 5, 6, etc. paint coating is irrelevant.
Instead, find an easy to use product that makes your car's paint LOOK GREAT - is easy to apply and affordable to re-apply.
Then good at washing your car and once a year, do a light polish and re-coat.
KISS = Keep it Simple Simon
And "yes" I've seen coated cars get this dirt stain ON the coating.
And when I say ON the coating I mean the dirt stain has impacted and embedded ONTO the paint in a way that normal washing does not remove it.
Thus the only way to remove it is via some mechanical means i.e. machine polishing.
Hahahahahahahaha - a whole year. How many people here have waxed a whole car more than once inside of a week for a slightly less than sane reason? (or is that just something I do?)
Great info as always! Here's an add on Question! How do you feel about layering & Coatings? Yay or Nay?
thanks Mike! To the OP Dave, there are pro's and cons to each. I have coatings on all three of my vehicles. One of those vehicles falls into the category Mike mentions where it doesn't get driven, the 2nd, gets driven very little, but the third vehicle is the dog hauler, grocery getter, and everything else. I call it my little UTE.
I originally didn't want to coat the UTE (Honda Fit) but did because after I moved to AZ, the Fit has to sit outside as of now I only have a 2 car garage (that will change soon). Because of this I opted to coat with CKUK and DLUX on all the trim, plastics and lights. Mainly for the monsoons, dust storms, and heavy amounts of constant UV slamming the car. Honda's are thin/soft paint to begin with so I didn't want CC failure in 6 months until I get a 3 car garage.
Coatings can provide ease of weekly washing and blow drying, because of the hydrophobic qualities. The longevity at least keeps the weekly maintenance pretty easy.
One could make the argument, as Mike points out, that regardless if a vehicle is coated or not, a typical daily driver will at least get a FULL detail annually, with Iron-x, clay, and some form of polishing, either HD Speed, 360, etc.. So the effort is pretty much the same.
I've never heard you can't remove a coating once it's applied and go back to wax, probably someone mentioned that because one might like the coating so much they will never go back?? A trusty DA, some pads and product will make short work of the coating though.
Great inofrmation, thank you for posting this Mike.
Thank you sir...
EXCELLENT Post Mike! Thankyou for sharing this!
Thank you...
In most cases I'd say "no". Instead - practice TOUCHING the paint carefully in every way you touch it,
Washing
Drying
Wiping
As always thank you for your input on this matter.
Thank you...
thanks Mike!
Good input Paul...
I sent the Email to Mike, some of the questions came from this vid
https://www.youtube.com/watch?v=93MmQhNwqxk&t=4s
Thank you for replying to your thread.
I've watched the above video and he actually makes some good points.
im in a group text with a few forum members and this comes up at least twice a month. ive dipped my toe in the pool of coatings on my personal vehicles but I'm never satisfied with them. i always end up going back to sealants, the overall look and fact I can better keep my car in top shape because I apply a fresh coat 2-3 times a year with a light yearly polishing to keep it looking its best satisfies me best.
I don't know if maybe I haven't found that one right coating to work for me either, I offer coatings to my customers and they seem to love them but personally I just don't, at least not yet
This is kinda one of the reasons I'm recently enamored with CanCoat; sealant longevity and ease of application with coating performance.
As for coatings degrading or removal, one of our cars had 3 different coatings on it this summer. Kinda labor intensive to insure complete removal (and I'm guessing you never get it ALL) but have had no issues going forward with what was the final choice.
I'm going to start doing some experimenting with cancoat and mckees paint coat application wise but to see how they do if applied in a "different" way then the traditional methods.
Thats one of the things I like about can coat...applies like a quick detailer or spray wax. Couple of spritzes in a short nap towel, wipe on buff off.
Thanks for the write up.
I've applied coatings to all of the family daily drivers and I've found it to have greatly simplified life. When I used sealants, I found myself doing a light polish/refresh along with a re-application of the sealant every six months. As the number of drivers in my family grew along with more going on in life, this was starting to become unsustainable.
Now that everything is coated, I've got all the vehicles spread out on an 18-month cycle which is much easier to sustain. I've noticed they stay cleaner between washes, and clean up much easier when washed. Due to the improved ease of washing, I've found the wash induced marring/swirls is significantly lower than when I used sealants. The vehicles tend to look better over that entire period of time vs sealants. At 12 months our coated cars look far better than sealed cars at 6 months.
The one thing I will say is I have to keep up with maintenance washes to keep this trend going. However I don't mind as washing is quick and easy and much easier to work into life than a full day detail.
Late to this, but thank you for saying this. I see a lot of justification and downright fanaticism with coatings, particularly on the sister site. Doesn't mean they don't work, but for me they're probably not the best option.
2-3x per year paint cleaning with a good sealant seems to be the best answer so far. Still hoping for something that resists road grime better.
May wanna give Gyeon CanCoat a try. Easy, quick application, coating like (as it is a coating, albeit a 'coating-lite' type) self cleaning characteristics and look, relatively inexpensive. 6 month longevity, longer perhaps if well maintained. Been in a CanCoat phase lately, it's quite a handy item in a variety of circumstances.
What are the differences between CC and UFF?
Sent from my SM-G930V using Tapatalk
UFF is a sealant and CanCoat is like a lite version of a coating. It has SiO2 in it which is found in many coatings to give that more durable form of protection. It also has some fantastic water behavior in beading and sheeting. Much more so than UFF. Also the self cleaning effects are really nice. The only difference needed is a prep wipe prior to applying CanCoat.
