richy
- Mar 27, 2007
- 5,158
I had the opportunity a year ago January to compound, polish and coat a 1949 Shepherd mahogany speedboat. It had 12 coats of varnish but needed some TLC. Here's the link below, but the picture links no longer work, so here's a few pics of the boat job to get an idea:
https://www.autogeekonline.net/foru...g-project-ive-ever-worked.html?highlight=boat
Here it is 10 years ago prior to restoration:
A 50/50 shot:
Same pieces all done:
So, now that you know the project, he had two more trim pieces he wanted polished to remove the swirls and coated. I used my rotary, one handed with a 3" foam pad + M100 followed by rotary, one handed using a 3" soft black foam pad + M205. They were then wiped down with Eraser and then coated with Feynlab Ceramic.
Here they are as they arrived:
Here's everything before coating:
Lastly, here is how the wood looks after being coated with Feynlab. It played very well with the varnish.
Thanks for looking!
A 50/50 shot:
Thanks for looking!
