I have used 22ple VX1 Pro, CQFinest, CQUK, and Opti-Coat Pro and 2.0.
None of them have been difficult to apply. Period.
CQUK and 22ple are 'easier', but let me stress again that none are difficult. (I should also add that I use the CQuartz applicator block wrapped in suede microfiber for application of each of these coatings... I have found this applicator to be much easier than the traditional yellow foam)
With that being said, I would vote for CQUK as a fantastic option for someone looking to provide great protection for several years, while also leaving a slick and very glossy finish. If you are seeking maximum durability, then simply go with Opti-Coat.
Im looking at putting a coating on my DD. Im new to the game... which ones are considered Top 3 or 4?
And which is easier for a first timer to apply? Heard a lot of bad first time experiences with Opti-Coat for example.
So says the distributor for Polished Angel...![]()
So far Carpro has caught my eye. The instructions seem simple enough... almost like a normal LSP. Apply, wait for XXX amount of time depending on temp, then buff of with provided microfiber towels.
That seems to be less scary than "wipe it in until its invisible", lol.
I'm not clear on whether Permanon Platinum or Hydro2 are coatings or hybrid coatings, but those are even easier than PBL!
HydrO2 claims about 2-3 months of durability... it is best described as a sealant not a coating.
With that being said, HydrO2 is a fantastic choice to apply on top of a coating for additional protection/boost.
is Hydr02 better as a topper than reload for opti coat ?
Better? No, both are fantastic.
HydrO2 is simply very quick and easy... But then again Reload is as well. You simply can't go wrong with either.
Polish Angel COSMIC is the easiest to apply. My results and yours will be identical
