joebruin77
Member
- Jan 1, 2019
- 272
Today I took out an old bottle of Collinite 845. It was like running into a long lost friend. I then put a coat of 845 on my wife's Honda Accord. It was very satisfying to apply the wax, let it dry to a haze, and then buff it off. For the last 3 or 4 years, I have used spray ceramic sealants, so it felt good to go back to an old school wax.
I have a couple questions about 845:
1) I vaguely remember reading that I should avoid applying 845 to black trim. Is that correct? Today, I did indeed avoid putting it on black trim. To protect the trim, I applied Griot's Garage 3-in-1 Ceramic Wax just to the trim. Is this recommended or is it ok to apply 845 to trim?
2) How does 845 compare in terms of durability to GG 3-in-1 Ceramic Wax? I know 845 does not contain any ceramic, so it supposedly doesn't last as long. But given that 845 dwells on the paint for several minutes while it dries to a haze and the GG 3-in-1 is wiped off immediately, it just seems strange to think that the GG would be more durable.
3) Where I live, summer temperatures routinely get above 100 degrees. I know that in general carnauba waxes don't do well in hot temps. But since Collinite 845 also has synthetic polymers in it, does it do ok in the heat? How long will 845 in hot summer temps?
Thank you,
Joe
Thank you,
Joe
