I think they are assuming that there is a glob of wax solids at the bottom of the bottle and then a bunch of watery stuff at the top. In that case the hot water would help melt the harder part and let it mix.Running it under hot water isn't gonna make it liquefy any more than it already is. Note where he said its like water
Anyway its a pretty runny product and more than likely its good to go.
I am going to wax under my hood with COLLINITE #845 but I have been shaking it for almost 20min and it still runs out on my pad and looks like water. It is not mixing up.
Any help would be great,
Thanks.
I just got a bottle yesterday from AG and mine is the same way .Might be time to buy a new bottle.....Just to be on the safe side...
For the last time that is how it's supposed to be, there is nothing wrong with it![]()
I have even thought about putting it in a small spray bottle just to spray on the pad.
Thanks for all the information, I kept shaking it and was still not sure so I put it in the freezer for a little bit and took it out and did the shake some more. It is some very thin stuff and a little goes a long way but it produces a great shine and was not hard to remove.
Thanks for all the input.
I did the same thing. It comes wattery at the top and you have to shake the living crap out of it to get it to mi with the solids at the bottom and I still got some chunks, no debating its reliability. I put 3 coats on every winter and it lasts to spring in hellish MN winters.Hey Jeffery,
It might be thin now but wait until the ambient temp is about 60 to 65 degrees and you'll see this stuff gets pretty thick.. I transfered mine to an Autogeek squeezable bottle which makes using it allot more friendly.
Autogeek Squeeze Bottle, Autogeek dispenser
