I think the yellow is inside the light bar but if it has to come apart why not add some LEDs inside right?If I truly wanted to make a difference to that particular vehicle I would've started with step #1 and that would've been the wheels & tires.
#2 would've been a much needed 4' foot wide "headlight restoration".
#3 would've been a thorough claybar session.
#4 would've been compound, then finally the Meguiars Cleaner Wax you're using minus the food coloring... Seriously, food coloring? Lol.
Not much difference.![]()
Sent from my Moto E (4) using Tapatalk
This is the 17th car I have owned and the rest of the car is fine. I only really need to paint the hood but it isn't going to match the rest of the car. I don't plan on using this car for anything else but being parked. It has 131 k warped rotors all around bald spots on the tire tread a questionable transmission the cooling system needs work but did not overheat and an abs fuse.
Why would I want a spoiler on a front wheel drive car?
To make it look like it's going fast while it's parked.
