Combo Product Review: Prima Amigo & Banana Gloss
TroyScherer
Active member
Sep 19, 2009
1,926
23
Prima Amigo
Manufacturers Description: From A.C.C.
What exactly is Prima Amigo? It really defies definition and product categorization. As the car companies like to say, it's a segment buster. Amigo is a paintwork cleanser...It is a polymer-based glaze...It is a super-fine polish which levels up to 3000 grit imperfections. Combine all three properties and you can see why we think it doesn't fall into any currently defined categories of car care product.
Mild cleaners in Amigo break up oxidation and remove dead paint. Embedded grime is gently lifted from the surface. Mineral deposits from water spots disappear. It is the perfect prep-step for well-cared-for paint that just needs a cleaning before wax. As a polymer-based glaze, it fills slight imperfections, adds stunning gloss while leaving the finish slick to the touch. The unique thing about Amigo is the polymer. Although it doesn’t provide protection the way Prima Epic will, it does allow you to go directly to your wax step without any bonding or durability issues. Try that with a normal glaze and your protection will simply rinse off. Prima Amigo allows you to fill imperfections, add gloss then seal it in with your synthetic wax. No other product on the market gives you what Prima Amigo gives you.
Product Information:
1. Manufacturer: Prima Car Care
2. Made in: U.S.A.
3. Packaging: Classy Blue Flip Top Bottle
4. Color: Medium Grey
5. Scent: Cherry/Vanilla
6. Consistency: Thicker
7. Price: $17.99 – 16oz​
Banana Gloss
Banana Gloss is a premium liquid wax with a deep glossy shine. If you want easy, waxing with BG couldn't be any easier. It works on hot paint, cold paint, in the sun or in the shade. It won't stain trim or leave white residue. It dries almost instantly, so waxing becomes a quick and easy project. If that wasn't enough, BG will actually fill and conceal some pretty heavy paint swirls. Banana Gloss has a complex resin that levels the paint while providing protection and durability. There is a touch of carnauba for added depth. There is quite a bit going on here. You get easy application, paint cleaners, no white residue, trim safe, concealing and of course, protection. All that is left is durability. You should see a good 45-60 days on a daily driver, but with a wax this easy, you may not find out.
2. Made in: U.S.A.
4. Color: Cream Colored Yellow
5. Scent: Chemical with Slight Banana Overtones
6. Consistency: Very Thin / Watery
7. Price: $18.99 – 16oz​
Application:
- I began by priming the face of a Black LC Flat Pad with Amigo; much like you would with M105 to use the KBM method.
- I used my PCxp for the application.
- I then began to apply it to half the hood and work it in.
- I went over each area using approx 4 section passes or until it was worked in and clear.
- I applied the Amigo to the entire vehicle before coming back and buffing it off.
- I then used a Red LC Flat Pad & PCxp to apply the Banana Gloss.
- Because it is so watery once the pad was primed I could easily do a few panels at a time.
- After every couple panels it took very little to be able to continue on.
- After letting the BG haze over for about a half hour I came back to buff it off.​
Finished Pictures:
I didn’t take any before or during pics. So unfortunately all I have are afters. I am working on getting a solid dark colored vehicle to do some 50/50 testing.
Hood
Body Lines
Passenger Side ¾
Passenger Side
Rear Quarter
Rear ¾
Driver Rear ¾
Beading Pictures:
I rained here 2 days after I finished. I had to stop for gas and thought I would take a few shots with my phone.
Notes & Observations:
Amigo
- Amigo is very easy to apply and work into the paint.
- After it hazed the residue was very easy to remove. It required almost not pressure at all. It felt like I was simply gliding the towel over the paint.
- Amigo left a very nice deep wet look.
- It seemed to mute the flake in my paint slightly.
- There was some swirl hiding I noticed but I think a solid color black vehicle would be a better test for this.
- I like that fact that it is acrylic based and as such will work well with sealants and waxes.
- This very well may be my new favorite glaze. I have / have used PB Black Hole, CG EZ Cream, CG Wet Mirror Finish.
- Would I buy this after I finish the bottle: The answer at this point is yes… I have used it a few times now and IMO it is product almost every detailer should try and keep in his arsenal.
Banana Gloss
- Because BG is so thin it is easy to apply via PC or by hand. I prefer by machine though because of the ease of application.
- BG works great in combination with Amigo creating a great one / two punch.
- The swirl hiding ability of BG on its own is good.
- The finish that BG leaves is slightly darkened and wet finish, while slightly muting flakes.
- IMO the overall finish is nice but slightly oily. It seems to attack more dust than other LSP’s.
- For me BG only last 3-4 weeks. I think this is due to the rain and dirt on the roads I drive on weekly.
- Would I buy this after I finish the bottle: No. It does leave a nice finish but IME it doesn’t last very long and attract to much dust.
Thanks for reading. Any additional comment or info is welcome
Great review!! :xyxthumbs:
Yea Amigo is like a AIO.
I think I'll get this and BG in my next order! Thanks! :D
Troy,
Really nice review!
An easy read; well organized and full of important detail. I like the various photo angles so that the reader can easily see how nicely the product makes that blue glow....:props:
Great reviews I like Amigo a lot I have been using it for a few years now. Never really had a desire to try BG due to its poor durability but I still want to try Epic, maybe one day.
Nice review. Looks pretty glossy too.
From the manufacturers description, it sounds to me like the Prima Amigo is just a mildly abrasive polish with a lot of fillers, "polymer fillers" if you go by what they say. Certainlly looks glossy though.
Nice review! Also you can use Amigo on a polishing pad and actually get some correction along with the filling properties it offers. I think you would have been more impressed on a solid dark color vehicle. It does amazing things on black cars.
As for BG I really enjoy it. I never have found any issues with it attracting anymore dust or dirt than any other carnuba based wax. Also it has more filling abilities on top of Amigo.
If you want to put in a little extra work you can buff off the BG Haze with a little Hydro. It gives an amazing shine and doesn't really take anymore effort.
Thanks for the comments guys.
tw33k2514 - Don't get me wrong. Under the right conditions I'm sure you could get 4 - 6 weeks. Mid Summer & no real rain storms.
Ted - Amigo is like an AIO but it lacks the protection I think we are all looking for. It is primarily a glaze after all.
Flannigan - I agree that nuba waxes in general attract more dust. But I have found that the more "filling" ability the more oily they are and thus attrack more dust. Also after using something like Fuzion you start to notice a difference. Fuzion seems to have some anti-static / dust repellant properties. And I also prefer a sealant for slickness and gloss. But that personal preference.
Troy,
Really nice review!
:iagree::whs::goodpost: :):)
I'm always truly impressed by those who dedicate their time and efforts in posting product reviews. Your exceptional review, IMHO, also meets these demanding standards!
{Note: PM is on the way.}
thanks for the review, I have some BG on the way from AG. not happy hearing about the dust attraction as I am going to use this on a black car
