Compounds are basically more heavily cut versions of polish...if you try a polish and it doesn't do whatever you are trying to achieve, you compound to "take it a step higher" as far as cut, then you go back to your polish to finish off the job, it all depends on how soft your paint is, but do a test spot to see if the polish does what you want.
