Thank you for the words of encouragement.
Above all else, a good forum is helpful to the members...
Next I'm tackling the white gel-coat above the rubrail which is oxidized the worst. How does this combination sound?
Meg's #91 heavy oxidation remover via purple foam wool(pc or rotary not sure yet)
Rotary for sure, PC type tools don't work well with long fiber pads.
A wool cutting pad would be better... something aggressive.
Meg's #45 high gloss polish via green polishing pad (pc)
The M45 is
non-abrasive, if you cut with a compound and any type of fiber pad on a rotary buffer you'll leave swirls in the gel-coat even though you might not see them if you're not in the right light or the right angle. A second machine step should be performed using a medium to fine cut polish.
That's assuming you want to leave a really nice finish? For some people or some boats, just getting the gel-coat cleaned, smooth and shiny is more than enough.
Mega # 56 by hand(lots of curved sections)
I have some 4 inch pads which should help.
That will work after your polishing step.
My concerns are that I might need to step up to a rotary. I just got the Makita 9227C in the mail.
For oxidized gel-coats, a rotary is really the way to go with a wool cutting pad. You can use the PFW and it will work as it's a very versatile buffing pad and it will finish out nicer than an aggressive wool cutting pad.
Do you think gelcoat is tough enough to learn on with purple foam pads or should I just step up to the wool pads it comes with?
Test with both, try the PFW first if it's not giving you the results you want fast enough switch over to the wool cutting pad that comes with the Makita. It's actually a very nice wool pad.
You need a spur, if you don't have one get one. You can use a screwdriver or something similar but nothing works as good as a spur for cleaning and fluffing the fibers of a matted-up wool pad.
In the below video, I show how to use a spur safely.
Tips for using a Rotary Buffer and the Flex 3401 on vertical panels
[ame=http://www.youtube.com/watch?v=gc_umhlote4&hd=1]Tips for using a Rotary Buffer and the Flex 3401 on vertical panels - YouTube[/video]
With wool pads on a rotary with megs#91 should I be able to finish well following with the megs#45 on the PC?(afraid I might end up with some holograms)
See my comments above...
