Confused about Fillers
Jossy92
Member
I have heard only bad things about fillers: That the purpose is to hide things from a customer. However, there has got to be a reason(purpose) why a professional detailer would choose that product as the best tool for the job. (Like an old classic car with original paint, but where there are certain spots where the paint is too thin to level?)
Also, is a pure glaze a filler? I read it was, because it fills the pores with oil. If paint is like dead skin when magnified, why is that bad.
Also, if I take a very mild cleaner that has a clear carrier and let it dry before buffing off, Wouldn't this be good if the paint residue in the crack now raises the bottom of the crack so I don't have to level the paint as much.
I just seems like a glaze is only a bad thing if you don't know when to use it. Like everything else here.....
OR, (To beat a dead horse), the paint isn't there for a master detailer to practice removing swirls, he/she is there to do the best thing for the paint over the long haul.
OR, (To shoot the dead horse)I don't know what a filler is for in terms of concourse detailing, but that purpose isn't for cheating and I sure would appreciate learning what that purpose is.
OR, (Hey that's a really nice looking dead horse)......
Kind of feel stupid, so I only want post this question once, and not sure how to ask. However, when I get the right answer, I will know what the question is and share it.:doh:
There's a lot of confusion over the word fillers as it means different things to different people, kind of like the word polish.
There are ingredients meant to actually deposit themselves in an effort to fill-in defects
There are ingredients meant to lubricate the surface so the abrasives don't simply scratch the paint.
My guess is most people don't delineate between the two? Or don't know if there's a difference and if there is what it means. I also think that sometimes online enthusiasts get so AR when discussing a topic to death they forget the goal as it relates to polishing paint and that's to make it look good.
So while water is a lubricant that won't fill, it's also not as slippery as a polishing oil. A polishing oil can fill but that doesn't mean that's how it's intended to be used or how it is being used regardless of original intent.
It's this losing sight of the original goal where the topic tends to go astray. I always tell people to find something they like and use it.
I'll let other's chime in...
One last time:
I have a well cared for 88 Civic with 260K on it.
The paint on the hood has 22 years of scratches on it. I don't have cc failure, but, I used a very mild cleaner which left a few scratches and the old scratches appear to be under the CC.
I have kept it well nourished, but am afraid to correct the paint. I think the term for the paint would be "delicate".
Would like to make it last and make it look better, if possible.
I guess my confusion is that I assumed I needed a filler. (I was just trying to focus this question on a single product and not waste a lot of time.)
Also, this question may be too specific, and the post might be more suitable for Detailing 101 as not too many members have 22 year old cars.
Thanks,
Jeff
You don't need a filler.
One last time:
Sorry for the delay in answering and sorry for any confusion on my part, usually when people bring up the word "filler" it's over the concerns of ONLY filling in defects when what they want is to REMOVE the defects, not simply fill them in.
22 years old with lots of scratches? How did they get into the well cared for car?
Did you buy it new?
Has the hood been repainted?
That's good because there's no way to fix clearcoat failure except to repaint the car or the affected area.
If it's leaving scratches it's not mild and you should stop using it as there are products that will remove defects without also instilling scratches at the same time.
If there are scratches UNDER the clear then the hood has been repainted and the work done was sub-par. There's also no way to remove them without removing the clear coat and at this point we're talking about having the hood or the car repainted only this time having someone do it right the second time.
Nourished? What have been applying for 22 years that nourishes the paint but it's still all scratched up?
It's real possible to make it look better, that would mean make the clear coat more clear so you can see the color underneath of it. It may not be possible to remove all the scratches. Even if you don't remove all the scratches, making the paint more clear will make it look better even with all the scratches.
Again, sorry for any confusion but you don't want a filler. IF you just want one product that will make the paint look better and not waste a lot of time, i.e. doing multiple steps then you want a one-step cleaner wax.
Get a bottle of ColorX. Wash the car and then clay the paint if it feels rough to the touch after you wash and dry the paint.
Take the ColorX and work a section about 16" to 18" squarish using a foam or microfiber applicator pad. I'm assuming you're doing your work by hand?
Allow the wax to dry and then wipe it off. While it's drying you can move onto a new section, again keep it small, you can't effective work a cleaner/wax to a clear coat finish and tackle a large area. Be sure to overlap into the previous section so you have a uniform appearance after you're all done.
I've only owned old cars and have worked on tons of old cars with paint in horrible condition.
Again, sorry for any delay in getting back to you, just got out of a meeting. Also sorry for any confusion on my part as to your questions about a "filler".
Post it here or in Detailing 101 but my answer will be the same.
If you just want to make the paint look better and only want to do one step besides washing and claying, then you want a one-step cleaner/wax and it sounds like you need a strong one step cleaner/wax which is what ColorX is.
If you want to remove SURFACE scratches then you could would have to do more steps. That could include,
Wash
Clay if needed
Rub paint out using a compound like Ultimate Compound
Polish paint with something like SwirlX
Then apply a wax.
Rubbing clear coats by hand is very time-consuming and a tad on the hard side because clear coat paints tend to be hard, that means it's going to be difficult to remove a little paint in the correction step which is where you remove the scratches.
Hope that helps...
Give me about an hour, I found an extremely scratched-up Saturn in the parking lot and the owner is going to let me do two spots on the hood.
  • One spot with just ColorX
  • One spot with Ultimate Compound, SwirlX and a wax
Then I'll show you the difference with pictures.
Hang tight...
LOL, I can see Mike out scavenging next door businesses for scratched up cars.
"Sir, your car is scratched up.... can I borrow it for a little while?"
Little do they know.... that is the best luck their paint has had since it was applied at the factory. :D
Hang tight...
Priceless! lol
This is why you fit right into the Autogeek Staff, Mike. You go out of your way to help someone.
that is very funny. i wish i was there.
and as funny as this is, "bo duke style" and all. another great, & fast, job by mike to help us all out. very informative and i thank you for taking the time to show us first hand the diff.
now i'm gonna go get some compound.
Please don't apologize, sometimes intention doesn't come over the internet (especially with my dry humor) and my intent in my second post was to help you help me (and any others will similar problems) by rephrasing my question.
I guess my question was what do I do when I am not sure if the defect to my original paind is damage to the clear coat versus separation of the base coat from the primer coat: May be just be an illusion. I am afraid to get aggressive.
You are the real deal Mike, you genuinely want to help people and it's appreciated it. You have set a standard that only comes from "treating other peoples cars like they were you own....you can't fake that.)
more when I figure out how to do a multiquote.............
Learned a lot in the last 2 years. ;) Prior to that I used Megs Cleaner Wax to passionately grind surface contaminants into the finish.
Undone most of this damage. However, still unsure of the nature of the problem.
You have answered my question. I am going to assume I have some sort of failure and proceed with caution.
Facing the front of the car, the hood has thousands of little scratches going in all different directions. They are evenly distributed over the center 1/3 of the hood. They don't look like pictures I have seen of cc failure.
I am going to answer your other questions:
Did you buy it new?
Yes, in '87
Never repainted
Used Megs ScratchX and not SwirlX [correction], gradually increasing pressure as I experimented over the period of a couple of weeks and didn't see a difference in the defects I was addressing.
One day saw straight scratches from my improper, too aggressive use of that great product and assumed the scratches were under the CC. Maybe just an illusion.
Nourished? What have been applying?
Prior to starting to learn:
Various products including car washes and finally settling on Megs cleaner wax.
After:
All Megs:
-Gold Class wash with foam gun
-QD + mild clay
-M07
-Cleaner wax
-NXT
I think this is the answer. :)
Thanks for finding my question: How to deal with a defect that can't be removed.
The cleaner the car the worse it looks to me. All I see are the scratches when the sun is at the right angle.
Again, sorry for any confusion but you don't want a filler. IF you just want one product...
Am doing it by hand to learn the "feel". Multi-step is fine.
You have set forth some options in your post. I will try ColorX if it turns out it's a surface defect.
BTW would usng M21/NXT make the defect stand out more because I've read it makes the paint really reflective ?
Was thinking of putting M26 over the NXT on the hood, but, then I read that it gives the paint more depth....might make it more noticeable. I want to have a really nice looking defect until I learn more about re-painting.
Hope that helps...
Thanks Mike, I learn slowly, but, it's fun and you know how to teach. I will post again when I get some pics.
Please don't apologize, sometimes intention doesn't come over the Internet (especially with my dry humor) and my intent in my second post was to help you help me (and any others will similar problems) by rephrasing my question.
Completely understand, years ago I coined the phrase,
"Time to push away from the keyboard"
I can be hard to understand intent from just the typed word and it's best not to make assumptions because that can get you into trouble. When in doubt, it's better to push away from the keyboard and maybe tackle another project.
I guess my question was what do I do when I am not sure if the defect to my original paint is damage to the clear coat versus separation of the base coat from the primer coat: May be just be an illusion. I am afraid to get aggressive.
If the basecoat is separating from the primer coat it's going to look like the paint has a rash. I started a thread on the topic of clearcoat failure but I have to be upfront and say that I don't have enough pictures added to it yet that cover the wide spectrum of different examples of this problem.
I keep a camera with me all the time just for this purpose and so far here in Florida all I've come across is extreme examples of clearcoat failure, nothing in the lesser range.
Here's the thread, as I come across more cars in parking lots with different variations of this problem I'll continue to build-up the photos from which to look at and compare to what's in a person's garage as this is a common problem.
The Clearcoat Failure Photo Gallery Archive
Here's the one I created on MOL, it has more variations to look through, I can't just copy and paste this over here as that would be unethical and illegal, so with time and persistence I'll continue to build a new archive of examples over here.
The Clearcoat Failure Photo Archive
Maybe scroll through the above two threads and see if the problem you're seeing with your car's paint looks like any of the photos in these two threads.
For the most part, the only thing you can fix when it comes to automotive paints are problems on the surface. You are limited as to what you can do by the thickness or film-build of the clear layer of paint.
So as long as the problem is topical and not too deep you can usually remove the defects completely, or improve the defect to the point that you can live with them versus repaint the car.
If you can get a picture of some of the worst areas and e-mail it to me I will upload it and insert it into this thread so everyone following this thread can chime in with their thoughts or suggestions.
It's kind of a pain but makes for easier reading, but here's how most people including myself do this, you need to switch over to edit mode and then break up the sections you want to address separately like I did above by sandwiching the different portions between quote tags.
Here's a screen shot showing what I'm talking about in this thread,
I'll create a thread with the above picture too because some people might not know what those little buttons do.
You were too fast and posted the below before I could post my follow-up but I think we're on the same page now. Let me add a few comments...
The Honda Pilot we bought new in 2004, original paint, never been wrecked, has little tiny cracks in the clear coat on the hood and that's the only place. They are very short cracks, about like this,
and are evenly distributed throughout most of the hood. They cannot be fixed without repainting because they are not a defect on the surface, they run throughout the entire layer of clear or the entire matrix of the clear layer of paint.
Sanding the paint would just remove paint and a deeper portion of the crack.
My guess is this is a heat related problem as it's only the hood that has been affected - engine heat under the hood, Mojave Desert heat on the top of the hood. It could also be related to expansion and contraction due to extreme temperature changes over time.
Just a guess... :dunno:
Yes, in '87
Never repainted
In the old days, a person was lucky if the paint lasted a few years, so 22 years is a pretty good run!
Used Megs SwirlX, gradually increasing pressure as I experimented over the period of a couple of weeks and didn't see a difference in the defects I was addressing.
Clear coat paints are hard to work on, especially by hand as compared to old style single stage lacquers and enamels. It has to do with the type of paint as old style paints are more polishable, they are more malleable, while clear coat paints are kind of like a layer of hard plastic on the car.
There's a term from the old days that goes like this,
"Hand rubbed lacquer finish"
The reason craftsman/detailers from days gone by could hand rub lacquer paint was because compared to today's paints it's very soft, except for white paint due to the pigment type.
This is why you don't hear the phrase,
"Hand rubbed basecoat/clearcoat finish"
You can hand rub out a basecoat/clearcoat finish but it's a ton of work. Heck rubbing out a lacquer finish is a ton of work, doing the same on a bc/cc finish is a ton of work multiplied by a zillion.
This is the primary reason tools like the dual action polisher have become so popular. The human hand cannot outperform the machine.j
but it can be done as I demonstrated in these two threads,
Man versus Machine
1-Step versus 3-Step Process by Hand
And show to a small section of a hood at every Detailing 101 class.
After:
All Megs:
-QD + mild clay
-M07
-Cleaner wax
-NXT
M07 is non-abrasive but a popular and very old product. Meguiar's A12 Cleaner/Wax is a very light cleaner/wax, I wouldn't try to actually remove swirls out of a clear coat paint with it as there are much better, faster and easier to get good results out of products, i.e. UC
Yeperdoo...
Something just can't be fixed.
The more you workout the fine or shallow defects the more the remaining deeper defects will stand out like a sore thumb. One of 2-steps forward, 1-step back kind of things but in my opinion I would opt for working out the shallow defects.
An philosophy I practiced when I used to detail cars full time was,
Take a car's finish to its maximum potential
This means do the best you can with what you have to work with. You can't fix every defect in every paint job but what you can do is take a car's finish to it's maximum potential.
Funny story, there was a group of guy that started a now dead forum and one of the members I'm guessing was making light of that saying and his signature line read,
Taking my signature line to it's maximum potential
Every time I read that it just made me laugh. :laughing:
Like Popeye says... (Paraphrased)
I yam what I yam...
ColorX compared to most cleaner/waxes is a fairly strong cleaner/wax, no one should read into this and think there are rocks in the bottle, it's not that kind of product.
Remember, besides product you have application material, application process, time and pressure. Lots of factors that go into how aggressive or non-aggressive a product can be.
BTW would using M21/NXT make the defect stand out more because I've read it makes the paint really reflective ?
I actually don't think so myself, not at this point where you've already been working on the paint and improving the overall appearance. At least no more so than any other quality paint sealant. Other's might have a different opinion.
I buffed out a car for a person one time that a couple of good ol boys painted for her in their garage. The hood had so much overspray on it you couldn't see the paint underneath of it. I removed the overspray and then buffed the paint clear, after restoring clarity to the clearcoat you could see wacky patterns in the metallic flake where the painter moved the spray gun closer and then father a way from the surface as he moved the gun back and forth.
At first the lady thought I caused the problem from the way I buffed out the car. When I explained to her the color and the metallic flake were UNDER the clear coat and that I was working on the top of the clear coat and there was no way I could affect the color of the way the flake laid down she eventually understood and thats when the old saying
You get what you pay for
Sunk in as it relates to letting a couple of good ol boys paint your car in their garage.
No one knew how wacky the paint job turned out till the overspray was removed and clarity restored to the clear coat, then it became very apparent. So sometimes fixing a paint job reveals a problem or defects in the paint job.
M26 is a good product, I always tell people to do a test spot when layering one product over another product, that is only apply the second product to a small section and then compare the test section to the surrounding paint with the first product on it and do this in different light settings. Make sure the topper is in fact taking the finish to a higher level and not diminishing the appearance. I've seen both thing happen with different products.
If you apply the topper wax to the entire car how would you know if it looked better or worse? By memory? Better to test.
Sounds good...
