Connections needed for pressure washer foam cannon?
lancerplayer
I have a Sun Joe SPX3000 electric pressure washer. I would like to convert the wand that came with the unit one that is shorter for easier maneuverability. More of a "machine gun" style as opposed to a "rifle" style.
However, I don't want to lose the ability to use the wand as intended (the "rifle" style).
The foam cannon I use has a 1/4" attachment that I use in the factory wand's quick disconnect
Is this possible? What connections do I need in order to make this happen?
Here is how the wand comes from the factory:
forum image hosting
online photo sharing
And when using the foam cannon with this set up, it looks like this:
upload gambar
I'm looking for the connections that will allow me to have a shorter set up like this:
image url upload
This is the foam cannon I have - Amazon.com: DUSICHIN SFL-001 Pressure Washer Jet Wash 1/4" Quick Release Adjustable Snow Foam Lance, Foam Cannon: Patio, Lawn & Garden
I had someone help me when getting a foam cannon and i got the kranzle fitting with it and it screws right in to the end of the gun now. You might be able to get a quick disconnect on it and be that short if that's what you want not real sure i haven't looked into it much after getting mine. Hope this helps you out.
Thanks for the reply. There are numerous fittings/adapters available that I'm overwhelmed about which is the correct option to get the results I'm looking for.
Also, I remember reading that the SPX3000 uses European threads, so most fittings/adapters won't work?
Hoping someone can link me to exactly what I need.
Yea i had one like you have and tried to get a flexzilla hose to work with it and couldnt i took it back and now i have a troy bilt 3100xp and it works great for everything but i forgot about those threads being different. Maybe contact their customer support and see if they have a fitting you are looking for.
Looks like M22 connections. So you might want to try an M22 1/4" DC adapter. Lots of places to get them. You could also put the opposite end on your wand so its a quick in and out.
OR
Just by a new trigger that has no wand and build yourself the ultimate short wand system.
Here is setup I am using. I made all my connections Metric Quick Disconnect easier to roll my pressure hose up with gun removed and quick fittings allows easy switching from Foam Cannon to 18" wand.
Apache 44048748 Metric Quick Disconnect Pressure Washer Adapter Set
M22M-by-3/8-Inch Female NPT
